1. IanK23's Avatar
    I messed up when rooting my phone, so now I need to connect it to Kies. It is not connecting and after a few Google searches I found out I needed different drivers, specifically Samsung USB Drivers 1.4.6.0 . I have searched almost everywhere, but I am still unable to find it. If you could direct me to the link where I can download them I would really appreciate it.
    Phone: Samsung Galaxy S3 GT-I9300
    01-23-2015 07:52 AM
  2. Rukbat's Avatar
    Kies, in Tools, has a "Reinstall driver" item. That installs the correct driver if you're using the correct version of Kies for that device. (Kies 2 won't work with newer devices, Kies 3 won't work with older devices. You should be running Android 4.3 or later, so you should be using Kies 3.) Kies - Windows and MacOS
    03-31-2015 12:54 AM
  1. Replies: 2
    Last Post: 05-31-2015, 02:27 PM
  2. Replies: 2
    Last Post: 03-31-2015, 12:57 AM
  3. G3 Double tap to wake screen
    By Sami Hanninen in forum LG G3
    Last Post: 01-25-2015, 01:44 AM
  4. Root samsung s5 sm-g901f
    By wasifraza in forum Samsung Galaxy S5
    Last Post: 01-23-2015, 07:51 PM
  5. Need a calendar widget to support different calendars
    By morjam401 in forum Android Apps
    Last Post: 01-23-2015, 07:30 AM
