- Gretting, i bought my Acer beTouch E400 with Android 2.1 eclair OS. i realized that the internal memory of my phone is getting lower each day, about 400kb to 1 MB. i did clearing some caches & cleaned up my message inbox, but it wipe up only a few kb. i tried uninstalling some of my application,but it'll keep on reducing my memory slowly again, and right now i don't have any application that i downloaded, only the default applications..all i can do for now is reset my phone using "factory data reset" in the Privacy Setting..and i'm tired to do that again & again every month..does anybody with Android 2.1 got the same problem? Please help me!!!!Thanks for your help guys!!12-13-2010 11:10 AMLike 0
- i realized that the internal memory of my phone is getting lower each day, about 400kb to 1 MB. i did clearing some caches & cleaned up my message inbox, but it wipe up only a few kb. i tried uninstalling some of my application,but it'll keep on reducing my memory slowly again, and right now i don't have any application that i downloaded, only the default applications..all i can do for now is reset my phone using "factory data reset" in the Privacy Setting..and i'm tired to do that again & again every month..does anybody with Android 2.1 got the same problem?12-13-2010 12:12 PMLike 0
- yup, but right now my phone only have the default apps,the same as it used to be when the 1st time i bought i,but that time i had 60mb free space,n right now it only have 22mb..thanks for your suggestion 'bout monitor apps, what's the best apps for monitoring space usage?12-13-2010 12:55 PMLike 0
- Forum
- Android Central Community
- General Help and How To
Leaking Internal Memory, Help!!
« text messages
New to Android »
