1. recharging's Avatar
    Hi guys,
    Samsung Galaxy S2 i9100
    4.1.2
    I9100B0LP9
    3.0.31-Jeeboo_Kernel_v1.2a+
    JZO54K.I9100XWLSD
    I mucked it up. After multiple attempts to reallocate my device memory into the internal USB storage with custom PITs via ODIN3 of versions 1.85 or 3.09, I was no longer able to mount my internal USB. It is detectable but neither mountable nor formattable in Windows 8.1 or Gpart.
    This is the extent of the damage.
    cat /proc/partitions
    major minor #blocks name
    7 0 7308 loop0
    7 1 10427 loop1
    7 2 43691 loop2
    7 3 48888 loop3
    7 4 6269 loop4
    7 5 2111 loop5
    7 6 22901 loop6
    7 7 8348 loop7
    179 0 15388672 mmcblk0
    179 1 20480 mmcblk0p1
    179 2 1280 mmcblk0p2
    179 3 1280 mmcblk0p3
    179 4 8192 mmcblk0p4
    179 5 8192 mmcblk0p5
    179 6 8192 mmcblk0p6
    179 7 102400 mmcblk0p7
    259 0 16384 mmcblk0p8
    259 1 524288 mmcblk0p9
    259 2 6291456 mmcblk0p10
    259 3 7872512 mmcblk0p11
    259 4 524288 mmcblk0p12
    179 8 15558144 mmcblk1
    179 9 15554048 mmcblk1p1
    254 0 7308 dm-0
    254 1 10426 dm-1
    254 2 43690 dm-2
    254 3 48888 dm-3
    254 4 6268 dm-4
    254 5 2110 dm-5
    254 6 22900 dm-6
    254 7 8347 dm-7
    7 8 5229 loop8
    254 8 5229 dm-8
    7 9 3150 loop9
    254 9 3150 dm-9
    7 10 4190 loop10
    254 10 4189 dm-10
    7 11 44730 loop11
    254 11 44730 dm-11
    7 12 41612 loop12
    254 12 41611 dm-12
    7 13 6269 loop13
    254 13 6268 dm-13
    7 14 42651 loop14
    254 14 42651 dm-14
    7 15 9387 loop15
    254 15 9387 dm-15
    7 16 13545 loop16
    254 16 13545 dm-16
    7 17 14585 loop17
    254 17 14584 dm-17
    7 18 4190 loop18
    254 18 4189 dm-18
    7 19 17703 loop19
    254 19 17703 dm-19
    7 20 15624 loop20
    254 20 15624 dm-20
    7 21 9387 loop21
    254 21 9387 dm-21
    7 22 7308 loop22
    254 22 7308 dm-22
    7 23 3150 loop23
    254 23 3150 dm-23
    7 24 20822 loop24
    254 24 20821 dm-24
    7 25 3150 loop25
    254 25 3150 dm-25
    7 26 15624 loop26
    254 26 15624 dm-26
    7 27 7308 loop27
    254 27 7308 dm-27
    7 28 3150 loop28
    254 28 3150 dm-28
    mmcblk1p1 is /emmc, which is also not mountable from CWM.
    The strange thing is, after restoring my Backups, I am still able to boot into the phone, and it does everything normally other than accessing media storage (i.e. all functions that run through the USB storage are no longer working)
    $ df
    Filesystem 1K-blocks Used Available Use% Mounted on
    tmpfs 422640 76 422564 0% /dev
    tmpfs 422640 0 422640 0% /mnt/asec
    tmpfs 422640 0 422640 0% /mnt/obb
    /dev/block/mmcblk0p9 516040 485112 30928 94% /system
    /dev/block/mmcblk0p7 100784 4452 96332 4% /cache
    /dev/block/mmcblk0p1 20144 8328 11816 41% /efs
    /dev/block/mmcblk0p12
    516040 438816 77224 85% /preload
    /dev/block/mmcblk0p10
    6192704 2014608 4178096 33% /data
    df: /mnt/.lfs: Function not implemented
    /dev/block/dm-0 7176 5112 2064 71% /mnt/asec/com.trackaroo.apps.mobile.android.Trackmaster-1
    /dev/block/vold/179:9
    15549952 8354208 7195744 54% /storage/extSdCard
    df: /mnt/secure/asec: Permission denied
    As can be seen, mmcblk1p1 does not even exist!
    Where do I go from here in order to restore a usable internal USB storage?
    01-24-2015 12:03 PM
  2. recharging's Avatar
    OK I gave up. Went through the whole spiel with Heimdall and ADB Shell. After much exploration (my first time in a unix command line), I roughly understood the file systems, but was pretty much resigned that I could not create or mount emmc. And so I did a factory reset without restoring in CWM.
    As I was resigned to my fate of losing my entire previous installation, during the reboot procedure, the phone FORMATTED the USB Storage!
    I now had the usable modified partitions 6GB/6GB, and decided to try to restore onto the newly formatted partition.
    Voila! All apps, data restored, partitions properly formatted and mounted. Hope this posts finds its way to the legions of frustrated.
    01-24-2015 06:38 PM
  3. Hovatek's Avatar
    thanks for sharing
    01-28-2015 02:05 PM
  1. Replies: 2
    Last Post: 01-24-2015, 07:26 PM
  2. Multiple ringtones possible?
    Last Post: 01-24-2015, 01:11 PM
  3. Replies: 1
    Last Post: 01-24-2015, 12:10 PM
  4. Not able to access phone storage error
    Last Post: 01-24-2015, 11:43 AM
  5. Why aren't my texts displaying after the other persons text?
    Last Post: 01-24-2015, 11:06 AM
