1. AndroidTechH3lP's Avatar
    Hello,
    I searched for my basic problem.. like many others else might also be looking for a solution but cannot find any.. many other threads are empty looking for an email app to check multiple a… | HTC Titan: Mogul, XV6800 | XDA Forums.
    I am using Samsung Note 3 32 GB and want an email client which can support multiple email accounts easily.
    1. I will have to configure around 15+ email accounts. including:
    3 gmail accounts
    1 hotmail account
    1 yahoo account
    and rest all others pop/pop3 accounts from different or similar domains.
    2. I will mostly be on wifi atleast 18+ hours a day (from home and office)
    3. Will only require to access emails from few accounts in urgency when needed on mobile data connection
    4. If there is somekind of good spam control available it will be great.
    5. If emails are not downloaded locally on mobile, that shall be better as well, as I receive more then 200+ emails everyday and dont want the device to slow down because of same.
    6. Checked various options on internet, each has pros and cons and makes me very confuse
    K9
    Cloud magic
    Blue mail
    Default email app
    Gmail
    Inbox
    Messagebox
    etc. etc.
    7. I dont want an application which will display advertisements..
    Please guide me to right solution.. I am willing to buy a commecial solution once I am satisfied with a trial account if available.
    Thanks for reading so far.
    01-27-2015 07:34 AM
  2. Crashdamage's Avatar
    AquaMail Pro should handle as many accounts of any type as you may have. Fast, stable and the most configurable email client I've ever seen for a mobile device. Has options for everything you can imagine. Also has the ability to backup your configuration for easy re-installs especially when you have multiple accounts to configure.
    I'm addicted to it and more impressed with it the longer I use it. Very good support from a fine developer by a very useful built-in help system, by email or user forum. Only $5. Free trial, but the free version will only handle 2 accounts and lacks a few features of the Pro version.
    https://play.google.com/store/apps/d....kman.AquaMail
    Android since v1.0. Linux user since 2001.
    01-27-2015 09:55 AM
  3. AndroidTechH3lP's Avatar
    Anything more want to try once before using
    01-28-2015 12:53 AM
  1. Why won't the wifi on my Gbox turn on?
    By Greg Koon in forum Ask a Question
    Last Post: 02-11-2017, 01:18 AM
  2. Replies: 3
    Last Post: 01-28-2015, 09:48 PM
  3. How do I reset Samsung S4 notification back to the default?
    Last Post: 01-27-2015, 11:14 AM
  4. Can the Samsung pick up a virus and how can I remove it?
    Last Post: 01-27-2015, 07:52 AM
