1. Greg Blomstrom's Avatar
    Hello,
    I get this annoying momentary message on the lock screen upon waking it up. The message is something like 'Your phone will run an additional 15 minutes ...' It comes on and then fades away. Is there a way to turn this off?
    01-29-2015 10:57 AM
  2. Greg Blomstrom's Avatar
    Figured it out. Found it in the '360 Security' app. In Settings, Boost and Power-Saver. Turned off 'Display result after screen unlocked'. I'm new to Android and probably set it when I first loaded the app. Thank you for your help.
  3. B. Diddy's Avatar
    Welcome to Android Central! Which phone?
    01-29-2015 01:02 PM
  4. Greg Blomstrom's Avatar
    Thanks and it's the Samsung Active S5.
    01-29-2015 02:59 PM
  5. B. Diddy's Avatar
    How new is the phone? Sometimes these reminders automatically stop after a certain number of times.
    The next time it happens, take a screenshot (or take an actual picture of the screen), and post it here. http://forums.androidcentral.com/amb...d-central.html
    01-29-2015 03:58 PM
  6. Greg Blomstrom's Avatar
    B. Diddy likes this.
    01-30-2015 07:08 AM
  1. Why does my Asus Zenfone screen turn on after locking it?
    Last Post: 05-21-2016, 03:45 PM
  2. Replies: 3
    Last Post: 01-30-2015, 09:23 AM
  3. Replies: 6
    Last Post: 01-30-2015, 07:19 AM
  4. What's wrong with my front camera on LG Optimus G Pro?
    Last Post: 01-29-2015, 01:12 PM
