How do I get my Samsung Galaxy S3 (AT&T) out of a bootloop?
DolevG
4
My Samsung Galaxy S3 (AT&T) is stuck in a bootloop.
Hello,
My galaxy s3 became stuck in a bootloop of carbon mod's booting screen. This occurred after I accidentally wiped all my data in cwm without making a backup, then rebooting my phone. I can enter recovery mode, I have wiped my dalvik cache, formatted my cache, formatted the system, wiped data, wiped cache, formatted data, but every time I hit reboot system now, before it reboots, it says Root access is missing. Root Device? And whether I press yes or no, it just loads in carbon mod's bootloop. I have tried to flash a TouchWiz rom through odin, it said failed. I tried a stock rom through odin, also failed. When I link up my phone to my computer, it doesn't register on the computer, so I can't copy files to it. I can't turn on my phone to download files. NOTHING is working. I desperately need help.
Edit: Forgive me if I sound retarded in this, I typed this at about 2 AM after 6 hours of trying to fix it. One more thing I forgot, I installed cyanogenmod 10.2.1 using their phone+PC installer, then, I booted into recovery, wiped everything without making a backup, then booted.
mbanu
Banned
Jan 24, 2015
41
Re: My Samsung Galaxy S3 (AT&T) is stuck in a bootloop.
Hello,
why would you format system? do you hve the stock ROM for your phone there?
DolevG
4
I was just following steps I found on google. None of them have worked. As I type this, my phone is currently in a bootloop that it has been in for about 30 minutes. I'm trying to see if I wait long enough, if it will turn on.
mbanu
Banned
Jan 24, 2015
41
nah, download stock rom > boot phone into download mode > flash rom via odin
DolevG
4
I've tried that, I can't flash any ROMs with odin, it just says fail. I managed to fix the issue though, I put an external sd card into my tablet, downloaded a stock rom, then flashed it through cwm. Although I have another issue now. I can't turn on the wifif on my phone. It is a 4.4.2 rooted TouchWiz Rom. Any suggestions?
mbanu
Banned
Jan 24, 2015
41
what errors do you get when trying to turn it on? you can checkout this guide on how to fix an Android phone whose WI-FI or Bluetooth wont turn on as it explains common causes
simonfairclough
Re: How do I get my Samsung Galaxy S3 out of a bootloop?
somebody please help me, i have a s3 phone and it has been stuck in bootloop for around 1 month now and its on its way to getting snapped iv read and looked at every possibitlity, took the power button off and tried pressing it with the button, tryed a million different techniques of holding button and inserting charger and taking battery out its unreal, apparently its something to do with the plastic casing because when i put the battery in it trys turning on streight away, but i also took the button casing off which makes no sence somebody please help me and come up with a solution otherwise its a waste of 130 quid
fallingOutOfLoveWfithTech
