1. Paisley's Avatar
    I've installed the icon pack Stock UI, and everything works fine, but for the few icons for which the pack does not have icons for I would like to assign one of the icons in the pack that are "alternatives" or are for an app I don't use. How? Thanks.
    01-31-2015 09:34 AM
  2. Aquila's Avatar
    If you long press on an app icon when it is on your home screen, you should get an option to "edit" and can then select from all icons on your device.
    Paisley likes this.
    01-31-2015 09:38 AM
  3. Paisley's Avatar
    Perfect, thanks!
    Aquila likes this.
    01-31-2015 09:55 AM
  1. Want to replace my Droid Maxx
    By comptech520 in forum General News & Discussion
    Last Post: 01-31-2015, 10:21 AM
  2. can not respond to 5 digit sms messages
    Last Post: 01-31-2015, 09:27 AM
  3. How long an e-mail can you dictate on Droid Razr?
    Last Post: 01-31-2015, 09:17 AM
  4. Replies: 1
    Last Post: 01-31-2015, 09:16 AM
  5. Replies: 1
    Last Post: 01-31-2015, 09:14 AM
