1. abdullah chaudhary's Avatar
    I went to have a shower and before i went i left my phone on my bed and i remember that it was at 70% battery life. when i got back to it, nothing, it would not turn at all or have a sign of turning on. The screen was off it did not vibrate when i tried to turn it on and also the charging light would not come on when i tried to plug it in.
    I also tried to take the battery out and then put i back in after 10 mins but still nothing. I also tried to get it in to download mode but that would not work either.
    Is my phone broke and how can i fix this issue. PLEASE HELPPPP!
    01-31-2015 04:27 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! The first thing to try would be a new battery, in case your current one failed suddenly. If that doesn't work, then it's possible the motherboard failed. You'd have to contact Samsung, but considering that the phone is probably no longer under warranty, a repair would probably cost about as much as a decent new phone.
    01-31-2015 10:22 PM
  1. Verizon not pre installing Samsung Galaxy apps store?
    By Closingracer in forum Samsung Galaxy Note 4
    Last Post: 05-27-2016, 05:18 PM
  2. Unlocked AT&T Samsung Galaxy S4 wifi update
    By fritothedog in forum Samsung Galaxy S4
    Last Post: 01-31-2015, 06:05 PM
  3. Why won't my Samsung Galaxy S4 charge or turn on?
    Last Post: 01-31-2015, 05:44 PM
  4. Replies: 0
    Last Post: 01-31-2015, 04:18 PM
  5. I think I soft bricked my phone, can I fix this?
    Last Post: 01-31-2015, 04:01 PM
