Yesterday and again today, I noticed my Nexus 5 getting very hot. I pulled it out of my pocket and noticed nothing out of the ordinary, other than the temperature and the battery drain. Since it is a Nexus 5, and there seems to be some issue with 5.0.1 and a memory leak, I wiped the data partition and rebooted. Unfortunately, the battery drain and heat were still there. I am in an area with poor cell reception, so I switched to airplane mode (with wifi on) even though I am always in an area with poor cell reception during the day and that hasn't caused these symptoms in the past. After the switch to airplane mode, the symptoms seemed to subside for a while, but after a few hours they returned. This morning, I return to work and the symptoms start right back up. I noticed a new symptom this morning that I hadn't realized was happening yesterday: my phone kept dropping and reconnecting to the wifi network. I assume that constantly losing and reconnecting wifi connection would be a battery drain, and today I had several drops in just a few minutes, but yesterday's battery history doesn't show many disconnects, or at least enough to tie them to the battery drain.
I'm not rooted, and don't want to just for this issue (especially if this might be a warranty issue), so wakelock detector isn't an option for me. Is there any other option that I can try to diagnose this problem?
I have included the battery history screenshots from yesterday and this morning.
Yesterday...
This morning...
Yesterday...
This morning...
