1. jam's Avatar
    everytime I am using the phone I notice my 3g signal keeps going in and out.....what causes this, or is it a phone problem...thanks (driod x)
    12-16-2010 05:01 PM
  2. RUSH's Avatar
    Regardless of which phone your using... two out of three times - it's cause by your network connection.
    Sometime refreshing the data connection usually fix the issue, unless your at a spot where you're not getting a good 3g connection.
    jam likes this.
    12-16-2010 05:09 PM
  3. Chris Kerrigan's Avatar
    Moving this to the General Help and How To Forum.
    12-16-2010 08:57 PM
  4. nycinter#AC's Avatar
    Had the same problem few weeks ago called sprint the guy had me do some things on my phone ,and that fixed it ,somehow some settings on my evo had changed .hope this helps
    12-21-2010 12:44 PM
  5. takeshi's Avatar
    Regardless of location? It should be pretty easy to check with your carrier to see if it's an issue with the network.
    12-22-2010 09:03 AM
