can i change the os in my phone
Hi there all ive a star note 3 n8000 and wondered if I can put in another os as ive only 150mb phone storage and im unable to remove some things in the set up I don't know anything about rooting and installing new os but if its possible I may see if anyone in a shop can do it ???
thanks x
Re: can i change the os in my phone
In theory, you can. However, in order for you to root a phone you'd need to either develop the method or find anyone that has 'cracked' it and published a step by step tutorial. For your device, unfortunately, it might be hard to find someone who has actually bought and rooted the device. IF you do root, to load a different OS you need to either build the OS specifically for your device based on Google's core files or load a ROM from someone who's already done the work specifically for your device. Again, you see where this is going...
In the meantime, review this guide for tips on how to maximize what little storage you have: http://forums.androidcentral.com/amb...-warnings.html
In the future, keep in mind that it is best to get a phone with as much Internal Storage as you can afford. Always consider the SD card as a convenient way to store media like music, photos, and videos, but not as a way to expand your ability to install apps.
it just said 4gig internal and assumed I get at least half this but not so. never mind thanks for that I only brought it for the screen size so thanks I will read the guide you put up.
cheers x
