Why won't my Android Digiland tablet turn on?
mfonseca154
Last night i left my tablet on along with Pandora and when i woke up this morning it woulnt turn on. After i went out for about 5 hours and came back home i went to check to see if it would turn on and it didnt. I got this tablet last christmas and really like it but i even tried to restart it by hitting the restart button and turn it on again but it still wont go on at all.
Re: My anroid digiland tablet will not turn on
Plug in the charger. Leave it charging overnight. In the future, don't let it drain past 40%.
(If something glitched, and the battery is fully discharged (the tablet should shut off before that), the protection circuit inside the battery tripped, and you'll need a new battery.)
Re: Why won't my Anroid Digiland tablet turn on?
Mine does this quite often Simply stick a paper clip end into the reset slot and then hold the power botton on for 2 seconds. Hope it works for you.
Thanks! I had to use the reset and power combo for a lot longer though, like for about 10 seconds. I just held it down until the tablet revived!
i had the exact problem..it would shut down ..after 2 days and randomly reappear..but since yesterday..it was not coming back. until ..searching on forums..someone mention a reset button,. actually it is write RESE with a small hole next to it. i use a paper clip..i did not have any needle and reset it pressing start button. now it works perfectly.
My son and I received this tablet as a Christmas gift and that is the only reason we own them. They are awful. His tablet has already crashed beyond repair and mine crashes almost every night. I have to hold down the power and volume down button for 10 seconds to reset it.
I just brought 2 digiland tablets for my kids, for Christmas. We plugged in the items and they will not charge at all. I've been trying to contact the company for a replacement on the tablets and cant get in contqcted with anyone.
My digiland tablet was a prize that I won last December. I've had it one year and now it won't turn on. It won't charge and it won't reset. Its now a worthless paperweight. What now??
FahadsTech
