1. Joachim Larsen's Avatar
    I am New to Android so i doesnt rally know much abput it, and I was just reading some diffrent stuff about icon packs
    (moonshine) and was wondering what third party launchers like Nova is?
    02-15-2015 02:48 PM
  2. ScottsoNJ's Avatar
    They allow customization. I use Nova Launcher Prime ( Prime costs $$) You can choose how big to have icons,how many rows,set it up how you would like it. 3 screens,4,5 etc.
    02-15-2015 03:03 PM
  3. Javier P's Avatar
    This Ambassador guide will help you to understand a bit more about launchers.
    http://forums.androidcentral.com/sho...d.php?t=299378
    Golfdriver97 likes this.
    02-15-2015 03:39 PM
  4. Joachim Larsen's Avatar
    Thanks, but is it easy to remove again if i for example dont like it?
    02-16-2015 09:04 AM
  5. Javier P's Avatar
    Yes. You can even keep it and switch between Nova and stock (or as many different launchers you use!) whenever you want.
    They save the different configurations, so you don't lose your custom tweaks.
    The way to switch launchers can differ from phone to phone. You can try going to settings - Home, that's the simplest way. What's your phone?
    Don't worry about having different launchers. One approach could be using your stock launcher for your daily use and switch to Nova just to play around. Once you get confident I'm pretty sure you won't use another launcher.
    Ask if you need any help with Nova settings.
    02-16-2015 09:16 AM
  6. Golfdriver97's Avatar
    A third party launcher like Nova may seem quite scary to use, but it is actually quite safe. You won't mess anything up, as you always have a stock launcher always ready.
    Nova can be useful in it's own way. Once your home screens are set up, you can make a backup of it. Then, if you have a need to reset the device, you just need to wait until all you apps are redownloaded, import the backup and you are done.
    02-16-2015 09:43 AM
  7. Joachim Larsen's Avatar
    Thank you, can't believe how nice people are on here. I have a LG G3
    Javier P likes this.
    02-16-2015 10:06 AM
  8. Javier P's Avatar
    Thanks. Yes we are
    There's a LG G3 subforum full of tips and tricks for your device. Take a look. Welcome to the forums.
    02-16-2015 11:24 AM
  9. Golfdriver97's Avatar
    To echo what Javier said, thank you. We all try to be as nice and friendly as possible, but there are those few, like anyone else in the world, who just aren't. Pay no attention to them.
    Have you downloaded Nova yet?
    From an AOSP M8
    02-16-2015 01:58 PM
  10. Joachim Larsen's Avatar
    Luckly i haven't meet anyone og those yet and yeah i have downloaded Nova
    02-16-2015 02:34 PM
  11. Mooncatt's Avatar
    Nova is probably the most popular, but not the only one. I personally use Next 3D, but have also debated a Star Trek themed launcher. There's themed ones, simple ones, and elaborate ones for whatever your heart desires.
    02-16-2015 03:06 PM
  12. Golfdriver97's Avatar
    Mooncatt is right. Lots of them out there. Point is have fun trying out different ones!
    From an AOSP M8
    02-16-2015 03:57 PM
  1. Replies: 5
    Last Post: 01-11-2016, 07:53 PM
  2. My Whatsapp is hacked, what should I do now?
    Last Post: 02-16-2015, 05:18 AM
  3. Replies: 1
    Last Post: 02-15-2015, 11:36 PM
  4. Replies: 0
    Last Post: 02-15-2015, 01:18 PM
  5. Replies: 1
    Last Post: 02-15-2015, 12:14 PM
