1. naz08101987's Avatar
    hi guys im new here
    need help, im on the galaxy s5 and after the loliipop update few weeks ago all downloads fail
    firstly how i download is: i use chrome, when asked to save a vid i get 3 option to select chrome, internet or my own installed (mxplayer).. so i select internet to download as if i select chrome it just opens video and plays in browser so i have to select internet(unless theres a way???)
    so this method has been working fine for past 2 years till now, as soon as i select internet from chrome to save vid it says downloads failed usually instantly sometimes it does do a few % then fails but thats rare
    what iv tried so far:
    -clear both browser history cache in app and using app manager
    -manually adjusted phones time by unticking automatic time update and unticking timezone
    -cleared the cache and data of download manager
    -turned phone off with battery out
    -booted phone up in recovery mode and done clear partition wipe(whatever its called)
    -uninstalled and reinstalled chrome
    -made sure phone has plenty of memory left(about 7gb left btw dont using sd card in it)
    -made sure theres no low limit set on mobile data as i have unlimited
    -used cleanmaster to clean all junk and etc
    -gone to setting and done factory reset
    but still same problem
    play store works itself downloads apps and stuff just fine so help guys plzz
    02-23-2015 05:59 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! How is the video that you want to save displayed on the webpage? Is it a link, or an embedded video? On my Nexus 5 using Chrome, if I long-press a link to a video, it give me these options:
    Open in new tab
    Open in incognito tab
    Copy link address
    Copy link text
    Save link
    If I select "Save link," it downloads the mp4 file to my Downloads directory.
    02-23-2015 12:38 PM
  3. naz08101987's Avatar
    its like link.. you click download and enter captcha and it asks what to open with
    i have 3 choices internet, chrome, mxplayer
    If i choose chrome or mxplayer it starts playing vid
    But i want to download which i do by choosing internet and download starts its just after lolliopo update it suddenly stopped working.. still works fine on mates phone
    02-23-2015 01:06 PM
  4. B. Diddy's Avatar
    So instead of tapping the link, long-press it and see if you get the Save Link option.
    02-23-2015 01:09 PM
  5. naz08101987's Avatar
    Nope long press dont work Bud.. thats prob due to the captcha code you have to enter
    02-23-2015 02:18 PM
  6. naz08101987's Avatar
    Anyone???
    02-25-2015 01:13 AM
  7. naz08101987's Avatar
    UPDATE: problem fixed
    same issue with my note 4 but sorted
    I was using the cleanmaster app on both pgones and in settings all i did was add internet to ignore list and switch realtime guarding off so one of them 2 i did has made my downloads work
    03-10-2015 09:44 PM
  8. naz08101987's Avatar
    Further update... few days later same issue, the problem i now know..whi n is the stock browser... any other browsers like opera mini work fine. Anyway one last attempt to make stock browser work by downling the app 'astro'
    03-21-2015 10:24 AM
  1. Transfer data from Samsung 4G Relay to S5
    By jdirt in forum T-Mobile Galaxy S 4G
    Last Post: 02-23-2015, 12:52 PM
  2. Transfer data from Samsung 4G Relay to S5
    By jdirt in forum Samsung Galaxy S5
    Last Post: 02-23-2015, 12:51 PM
  3. How do i connect my Galaxy S5 to my 2005 Nissan Altima?
    Last Post: 02-23-2015, 09:11 AM
  4. Replies: 0
    Last Post: 02-23-2015, 04:23 AM
  5. Replies: 0
    Last Post: 02-23-2015, 02:36 AM
