1. secrecyguy's Avatar
    Yes, I did a search and I can not find it. I thought the settings is under "security" or "about" but I can not find it.
    My phone is failing and I need to reset it. Thanks!
    02-24-2015 02:57 PM
  2. SpookDroid's Avatar
    You can do the 'hardware buttons' method:
    Perform a hardware factory reset - Samsung Galaxy S® III 16GB (non-Sprint Spark™)
    Or you can go into Settings, Accounts, scroll down to the Backup section and select BACKUP AND RESET. There just select FACTORY DATA RESET
    02-24-2015 03:02 PM
  3. secrecyguy's Avatar
    Thanks!
    02-24-2015 11:39 PM
  4. SpookDroid's Avatar
    02-25-2015 11:00 AM
  1. Home Screen Image Randomly Resets
    By Jason Blonar in forum Samsung Galaxy S5
    Last Post: 02-25-2015, 08:09 AM
  2. Replies: 1
    Last Post: 02-24-2015, 05:18 PM
  3. Replies: 1
    Last Post: 02-24-2015, 03:24 PM
  4. How do I add more pages on my home screen on the Droid Max?
    Last Post: 02-24-2015, 02:30 PM
