1. Nikolay Stoynov's Avatar
    I have Aftershokz Sportz M3 headphones that use bone conduction to transmit sound. Since I'm hearing impaired, this works very well for me. I wish to test them as a hearing aid device: use the mic to capture the sound from my surroundings and pass it to the headphone's speakers. Is there an application suitable for such task? If no, is it possible to create one? (I'm hobbyist programmer with zero Android experience, but maybe I could make it with some help from you)
    Thanks!
    03-04-2015 08:23 AM
  2. Balalapp's Avatar
    Николай, такие приложения есть на Google Play, наберите в поиске "слуховой аппарат". Они позволяют усиливать звук в фоновом режиме, известная проблема это небольшая задержка звука. Думаю качество работы данных приложений целиком зависит от качества микрофона вашего мобильного устройства.
    03-04-2015 09:13 AM
  3. Nikolay Stoynov's Avatar
    Thanks, I was searching the wrong category!
    (I feel stupid for asking such simple questions)
    03-04-2015 03:41 PM
  1. How can I remote my Panasonic TZ60 camera via my Samsung S3 mobile?
    By Paul Kingfisher in forum Samsung Galaxy S3
    Last Post: 03-06-2015, 03:12 AM
  2. Why can't my gallery generate thumbnails?
    Last Post: 03-04-2015, 11:33 AM
  3. Why do my dad's contacts keep appearing on my Whatsapp?
    Last Post: 03-04-2015, 08:54 AM
  4. Why does my LG G3 drop calls a lot?
    Last Post: 03-04-2015, 08:15 AM
  5. Is my call blocked ?
    Last Post: 03-04-2015, 08:14 AM
