1. robert7107's Avatar
    Bought a meenova sd card reader to transfer music from my sd card to phone (nexus 6) can't figure it out.
    03-06-2015 11:11 PM
  2. Rukbat's Avatar
    Plug the card into the card reader and the card reader into the phone. Open a file manager (ES File Explorer, MyFiles, Total Commander - whatever your favorite one is), copy the files from the SD card and paste them to the phone. (With Total Commander in landscape mode you can open 2 windows, the card and the phone, and just drag&drop.)
    03-06-2015 11:28 PM
  3. robert7107's Avatar
    I have the nexus media launcher.. I try again
    03-07-2015 09:05 AM
  4. robert7107's Avatar
    I got it to transfer from card to phone using reader but not able to transfer from phone to card???
    03-17-2015 05:03 PM
  5. Rukbat's Avatar
    From 4.4 om, the card is part of the file system - only apps with permissions to write to that folder can write to it. If you root the phone, you can run NextApp SDFix: KitKat Writable MicroSD (root) to change that back. (Restart after running it.)
    03-20-2015 12:13 AM
  1. SD card failure - Note 4 AT&T
    By Joe Mathy in forum Samsung Galaxy Note 4
    Last Post: 03-07-2015, 09:46 AM
  2. How do I fix my battery charge?It won't increase or decrease.
    By AceActs Productions in forum Hardware Hideaway
    Last Post: 03-07-2015, 12:17 AM
  3. Replies: 0
    Last Post: 03-06-2015, 09:54 PM
  4. Preowned Galaxy S4 rooted or not?
    Last Post: 03-06-2015, 09:38 PM
  5. Replies: 0
    Last Post: 03-06-2015, 06:49 PM
