Hi all,
I am new to android and would be very grateful for anyones help, I attempted to upgrade my newly UK purchased moto G xt1032 4.4.4 Kitkat to Lollipop 5.02, However things didn't go as planned.
I followed all of these steps perfectly until i got to step.10 .. then things went wrong.. when i selected "wipe cache partition" the phone rebooted to the lock screen, now i can't get the phone into recovery mode.. every time i select recovery option instead of getting the dead android (no command), the phone reboots to the bootloader lock screen. PLEASE HELP !!
I followed all the steps correctly.. the phone is rooted and flashed as instructed in description, using r2-motog-superboot and CWM Recovery. I still have the Supersu app showing and i have re-flashed CWM Recovery but still have the same issue. I am still on Kitkat 4.4.4. The 'wipe cache partition' also removed the Gapps and CM12 KonstaKANG files from the SD internal memory.
Any help will be much appreciated ...
I NEED HELP PLEASE!! THANKS
03-15-2015 09:33 AM
