1. esan013's Avatar
    Hello, guys,
    After the most recent system update on my HTC Evo 4G (3.70.651.1), it seems that the "audible selection" sound (the sound the phone makes when you tap on almost anything on the screen, including the four "buttons" below the screen), the lock/unlock sounds, and the touchtones have all decreased in volume. They are very faint.
    I've tried Menu > Settings > Sound > Volume, but all of the sliders are turned all the way up. Help?
    Thanks
    12-24-2010 09:53 PM
  2. Mobeans21's Avatar
    I'm having the same problem with my new EVO. The audible selection volume became very low all of sudden, when unlocking my phone and making selections. I tried the same things, menu, settings etc. No change. turned everything all the way up, still no change. Have you found a solution to this problem?
    Thanks
    01-11-2011 09:35 PM
  3. barhtc's Avatar
    Audible selection is controled by "Media Volume" Menu>Settings>Sounds& Display> Media Volume
    01-18-2011 07:37 AM
  4. takeshi's Avatar
    A better sound levels app may help to centralize all the volume controls.
    01-19-2011 08:29 AM
  5. esan013's Avatar
    The HTC EVO 4G has separate "Sounds" and separate "Display" menus.
    02-18-2011 02:15 AM
Tags for this Thread
