1. gfederline9's Avatar
    how to change apps position on Galaxy nexus
    so I am on the home screen , and look down you can see the circle button with 6 dots inside , I press the circle and goes into a page with Apps and Widgets , there I have a lot of apps , but I found out they are place in the order I download them , I want to move them to the position I want ,
    But I found out everytime I long press on an apps it bring me back to the home screen , instead of stay in the apps and widget page ,
    what to do , I hope I can add a screen print of my Galaxy nexus , but can't
    this is the screen print of my galaxy nexus apps and widget page
    03-24-2015 11:00 PM
  2. gfederline9's Avatar
    03-24-2015 11:03 PM
  3. gfederline9's Avatar
    03-24-2015 11:03 PM
  1. Google Play Store Suggested Apps Pop Up
    By dallusglockin in forum Android Apps
    Last Post: 03-26-2015, 09:51 PM
  2. How do I change my keyboard back to all black on my Galaxy S3?
    By AC Question in forum Samsung Galaxy S3
    Last Post: 03-26-2015, 01:33 AM
  3. How do I change the apps position on my Galaxy Nexus?
    By gfederline9 in forum Ask a Question
    Last Post: 03-25-2015, 12:59 AM
  4. How do I install a sim card on the Galaxy S5?
    Last Post: 03-24-2015, 11:11 PM
  5. Rapid charging on S5 Active
    By faith3935 in forum Samsung Galaxy S5 Active
    Last Post: 03-24-2015, 10:41 PM
