1. Ares30's Avatar
    I think that downgrading will help my tablet to stop crashing because it will stablize it I guess. Please let me know if you disagree with me and if you guys know how to safely perform this task.
    My tablet is rooted but I dont have any custom recovery for my device (my tablet is so unpopular)
    03-28-2015 07:01 AM
  2. itguyjax8430's Avatar
    Unless the manufacture has a factory image for ICS for the tablet you probably won't be able to downgrade it. I don't see that CyanogenMod has any support for your tablet. If you are rooted try a app called Greenify a try. It automatically hibernates apps on the device to save battery and could help keep apps from running in the background. This might free up some needed memory for you.
    https://play.google.com/store/apps/d...greenify&hl=en
    03-28-2015 07:09 AM
  3. Ares30's Avatar
    I just installed greenify yesterday and ever since then, my device hasn't overheated or crashed or anything like that. I guess Greenify is helping to hibernate all the bloatware running in the background.
    03-28-2015 04:44 PM
  4. itguyjax8430's Avatar
    Awesome! Yeah it is a great app for taking control back of your phone. I have been using it for a good while and love it.
    Ares30 likes this.
    03-28-2015 05:08 PM
  1. How can I fix colored lines on my screen?
    By AC Question in forum Samsung Galaxy Tab 3
    Last Post: 06-07-2015, 01:58 PM
  2. Any app to glow the edges of the screen..
    By Srvgodara in forum Google Nexus 6
    Last Post: 03-30-2015, 06:06 AM
  3. Why does my 7 inch Prontotec tablet keep erasing all my apps?
    By Ares30 in forum General Help and How To
    Last Post: 03-29-2015, 02:14 PM
  4. Replies: 1
    Last Post: 03-29-2015, 02:35 AM
