1. meeoow_meeoow's Avatar
    lenovo a536
    03-31-2015 04:02 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Can you tell if it works when unlocked? If you're unable to unlock the screen since it won't register a touch, I'm guessing you can't tell if it works when unlocked. The digitizer may have failed, which would require you to bring the phone to a repair shop.
    03-31-2015 12:06 PM
  3. Zdravka Ivanova's Avatar
    Hello,
    I have the exact same problem on my Lenovo A536. I've had it for almost a year now and this morning after locking the screen, the touch screen just stopped responding. I take out battery, turn it on and the touch screen works until I lock it and then bam - it stops responding again, I can do nothing. The volume and power keys work all the time, just the touch screen gives me trouble. This is very strange , because it works just fine until you lock the screen. Any idea? Thanks!
    09-02-2015 03:33 AM
  1. how to make my imo ringtone in silent mode
    Last Post: 06-16-2016, 05:04 AM
  2. Having problems updating Nexus 6 to 5.1?
    Last Post: 05-21-2015, 01:28 AM
  3. how to istall another rom in CWM recovery for Samsung galaxy s4. please help
    By Siddharth Ray in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 03-31-2015, 09:48 AM
  4. Stock lock screen?
    By robert7107 in forum Google Nexus 6
    Last Post: 03-31-2015, 06:29 AM
  5. Why does my phone restart when I try to install or uninstall any apps?
    By VishweshG in forum General Help and How To
    Last Post: 03-31-2015, 02:58 AM
