1. markl86's Avatar
    I have a galaxy ace 3. Since I have had the phone I have had issIues with charging the phone. I find that if I let the phone run out of battery, i struggle to turn it back on. I plug it in and it shows the charging symbol but when I try to turn it back on, it doent turn on. If i keep trying with this then after 30 or so attempts with this, I can finally get it to charge and turn on. Most of the time it will show charging but when I try to turn it on, the samsung writing comes on, then the phone dies again and stops charging. I am completely stumped with this one as my logic is that if it was the battery it wouldnt turn on at all or wouldnt charge. Thanks in advance for any help or advice you can give
    04-02-2015 06:47 AM
  2. belodion's Avatar
    Welcome to Android Central.🙋
    Discharging the battery fully before recharging is bad practice. Read this article by Rukbat:
    04-02-2015 07:01 AM
  3. VidJunky's Avatar
    First let me say that it is really bad to allow phones these days to turn themselves off due to low battery. You should discontinue that practice right away, by finding some way to charge it until you can get to a point where you can fully charge it or turning it off manually before you think it will turn its self off. Have you ever held the power button on a PC to shut it down, and then notice that when you restart it often it will go through a disk check and pop up all kinds of warnings that the computer shutdown improperly? That is essentially what you are doing to your phone when you allow it to power down due to low battery. When you shut it down manually it has time to run all of its shutdown routines and finish processes that need to be ended and so on. Add to the hardware issue you are subjecting your phone to you are also doing harm to your battery. You may have already noticed that your battery life is shortening, if not consider yourself lucky and avoid it by discontinuing this practice. The rough start is likely due to processes not closing out properly and your phone trying to start from an un-natural state. I think if you do this one little thing you will notice that you stop having these issues. There are several good write ups on lithium batteries on Google that can explain not only how to better care for them but also the damage that can be done by running them to zero.
    04-02-2015 07:10 AM
  4. markl86's Avatar
    It never fully discharges, always turns off at around 10%. I put it on charge last night at around 12:30, woke up this morning and it had not moved from where i put it on and still would not turn on, this was after been on charge for a good 7 hours. Surely this should have worked even if it was the fact that the phone had ran out of charge
    04-02-2015 07:12 AM
  5. VidJunky's Avatar
    Yeah but I feel like the point is still valid it's turning its self off due low charge, and I still feel if you wouldn't allow it to do that your trouble powering on would stop. Have you ever had issues with powering on during times when you were able to charge or turned it off before it could power down?
    04-02-2015 09:50 AM
  1. How can I recover photos from my phone?
    By Mangkudun Sati in forum Samsung Galaxy Note 4
    Last Post: 06-12-2015, 01:55 AM
  2. ADS on A/C
    By roy ellis in forum Ask a Question
    Last Post: 04-06-2015, 08:16 AM
  3. Why does my music app stop when I hit the playlist tab?
    By jmhardwick in forum Samsung Galaxy Note 3
    Last Post: 04-03-2015, 12:20 PM
  4. Can't see photos saved to sd card with camera app from the phone
    By Mangkudun Sati in forum Ask a Question
    Last Post: 04-02-2015, 10:56 AM
  5. Where are my delivery reports, and how do I check them?
    Last Post: 04-02-2015, 09:22 AM
