1. David Macias1's Avatar
    how to connect an android lg phone to A/V onkyo A/V receiver
    04-04-2015 11:00 AM
  2. wms3's Avatar
    Assuming you want both audio and video you need to see if there is an HDMI converter for your particular phone. If you just want audio get an analog cable to connect from your headphone jack on the phone to an AUX input on the receiver.
    Posted from my Sammy Note 4
    04-04-2015 04:45 PM
  3. P Carter's Avatar
    Some older receivers from Onkyo won't support Android (only ipods and iphones), so you might be out of luck if you try to use the USB port; however, you can still get a cable that has a male 3.5mm into your android and a red and white cable on the other end to attach to your receiver. I hooked mine up to the TV port (you can choose which you like) and it works great.
    06-23-2015 11:07 PM
  1. Replies: 2
    Last Post: 10-02-2017, 10:49 AM
  2. Replies: 6
    Last Post: 07-14-2015, 08:22 AM
  3. Why can't I get my wifi to connect?
    By fapperior in forum Samsung Galaxy Tab 3
    Last Post: 04-12-2015, 10:43 PM
  4. How can I get documents to download from my email account?
    Last Post: 04-05-2015, 10:30 AM
  5. How do I set Views in the Eclips that show any device such as Eclips?
    By mahshidf in forum General Help and How To
    Last Post: 04-04-2015, 10:06 AM
