Can I connect an otg to my virgin LG Tribute cell phone?
A
AC Question
can i connect an otg to my virgin LG Tribute cell phone?
I have android version 4.4.2. My phone doesn't recognize the otg
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
Re: can i connect an otg to my virgin LG Tribute cell phone?
The phone won't "recognize" the cable, it will only recognize something you plug into the cable - a keyboard, a mouse, a memory stick, etc. But even the $2 ones you can get on eBay (I use one) work.
