1. Alon Solomon's Avatar
    Me Alon Solomon, is very much troubled about the battery life of my android phone.
    Actually the problem have arisen after using the phone for 9 months usage.
    The battery drains away very fastly which shouldn't be the case.Plz give suggestions regarding this..
    Thanks,
    Alon Solomon.
    04-06-2015 01:40 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which phone do you have?
    First, review this guide: http://forums.androidcentral.com/amb...ving-tips.html
    Next, show us some battery stats. Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/amb...d-central.html
    04-06-2015 02:03 AM
  3. ronandrew's Avatar
    Hi alon, you are right android phone battery life is low. If you want increase battery life so you use maximum mh power battery like 4000mh. i hope your battery life increase.
    04-06-2015 04:57 AM
  1. My photos have disappeared on my Galaxy Note 3, can i get them back?
    By lisadeboer in forum Samsung Galaxy Note 3
    Last Post: 04-07-2015, 04:28 PM
  2. Phone restart in start screen.
    Last Post: 04-07-2015, 11:41 AM
  3. Replies: 1
    Last Post: 04-07-2015, 07:33 AM
  4. Replies: 3
    Last Post: 04-06-2015, 09:08 PM
