1. AC Question's Avatar
    I have tried turning my phone off and taking out the battery but when I turn it back on I keep getting the "Android is upgrading... Optimizing application 1 of 1" message. I have also tried pressing the Power off button, volume down and home buttons at the same time and I get the message "Warning!! A custom OS can cause critical problems in phone and installed applications. If you want to download a custom OS, press the volume up key. Otherwise, press the volume down key to cancel."
    04-07-2015 08:22 AM
  2. Golfdriver97's Avatar
    Welcome to Android Central. If you click volume up, home and power to reboot, that should bring you to recovery. Try a cache clear and see ig that helps.
  3. Golfdriver97's Avatar
    04-07-2015 08:41 AM
  1. Replies: 2
    Last Post: 04-09-2015, 05:03 AM
  2. Replies: 1
    Last Post: 04-07-2015, 09:09 AM
  3. Is there an app with a quiz to teach students about pregnancy?
    Last Post: 04-07-2015, 08:50 AM
  4. When I press the home key I get Ok Google. Why?
    By Cathy Carnell Chapman in forum General Help and How To
    Last Post: 04-07-2015, 08:43 AM
