Can I have two dialers on the same phone?
relztrah
15
I already use Google Voice on my phone with its own dialer. I have a separate Ring.to number and I would like to use it on the same phone. Ring.to uses the Grooveip dialer. Is there any problem having two dailers on the same phone?
srkmagnus
Retired Moderator
May 23, 2010
13,434
210
No, there won't be any issues using two different dialers. You'll just have to open the one you want to use at that particular time. Also, certain actions prompt you to choose a certain action, such as selecting a phone number via the web, and you'll either have to set that action for all the time or one-time only.
ThatDude
