1 ) 1 of the worst thing about android is the app drawer ,
with samsung touchwiz , moto ui , htc sense you can change apps position and make folder in apps drawer
BUT stock android you cannot change apps position and make folder , it default sort apps by alphabet ,
if you long press the app , it takes you back to the home screen
changing apps position , customise apps position is a must and android still not doing it , suck
2) there is no google store , android store , even if there is a few samsung store , they are nothing compare to apple store genus bar
:-X
:-X
