1of the worst thing about android is... :-X
gfederline9
142
1 ) 1 of the worst thing about android is the app drawer ,
with samsung touchwiz , moto ui , htc sense you can change apps position and make folder in apps drawer
BUT stock android you cannot change apps position and make folder , it default sort apps by alphabet ,
if you long press the app , it takes you back to the home screen
changing apps position , customise apps position is a must and android still not doing it , suck
2) there is no google store , android store , even if there is a few samsung store , they are nothing compare to apple store genus bar
:-X
1) You can always use a different launcher, which is actually what they're for. To cater to different tastes (in this case, the ability to create folders in the App Drawer, which for many of us, is not useful).
2) I'm assuming you either mean app quantity or you have an Amazon device or a knock-off one (or live in China, perhaps?) but there IS a Google Store (Called Play Store) with all apps to pick. Amazon has its own store, as does Samsung. And actually, in number (if not yet in quality) the Play Store surpassed the Apple Store or got too close IIRC. Not really understanding what your complaints are here hehe especially on the Store front. Yeah, there are apps that devs only bring out to iOS or take longer to arrive to Android, but they're really rare nowadays.
i mean apple store, the shop , i mean a shop in real life , the apple store and its genius bar inside
android or google have no retail store genius bar
samsung have a few retail store but nothing compare to apple store , see how much rent apple have to pay for those shop and land their thousands and thousands of apple store build on
Aaaaah, got it. Well, I think there were talks of Google acquiring something to make physical stores a reality, but I still don't see the value in that with the myriad of options you have for Android devices, unlike Apple, which has their own models and that's it. The Samsung 'stores' inside BestBuys are more than enough for what they are, in my opinion.
But yeah, Apple has that advantage because it manufactures and promotes and sells their own products.
apple probably paying billions billions dollars of rent for all those thousands Apple Store all over the world
see those Apple Store is all locate in busy and famous popular area , popular street , the rent must be billions
caritas
