A
AC Question
When i play video from YouTube, sound and video are not in synced. Let me know how to fix it.
Thanks in advance!!
Thanks in advance!!
Not sure if this will help, but go to Settings>Developer Options (if you don't see it, then go to Settings>About Phone, and tap Build Number 7 times). Then switch the media player--if it's set to NuPlayer, change it to AwesomePlayer, or vice-versa. Now see if the problem persists.
Hi,
I have Samsung S6 Edge and notice same problems with delay in sound when i check youtube.
I have a Iphone and checked and no delay on the iphone but seeing the problem with the Samsung Phone.
It would be nice to have more people looking for this because its quite anoying.
I have reset phone and also emty chache and done all i can to eliminate the problem but nothing works.
Its not a huge delay but you see it quite easy if you just look for it.
/TL
Love the phone in all other areas...
Hi! I cant seem to find the media player option when im at the developer options. I am using a galaxy note 3. Could you help advise on what i could do?
I also have an A3, I found going into dev options and 'forcing gpu rendering' fixed the problem...Me too, i cant find media player option, im using samsung A3, what should i do?
Any power saving modes turned on?
