How do I Login to Wifi where a password is required?
  • Start date Start date
A
AC Question
We have a guest login at work but we must use a password to make the connection and complete the log in. The phone keeps saying it is connected but it keeps dropping the connection and the screen to enter the password never appears. Any ideas on how to get that screen to appear so that I can log in? Thanks for any help.
Re: Login to Wifi where a password is required
Welcome to Android Central! Which phone? Some phones actually have a setting to bring up login screens as a separate popup (I think the HTC One M8 is one of them).
What happens if you open a browser and go to any URL? Does it just give you an error, or does it take you to the login screen?
araelbenjie
