Originally Posted by
John 101 Try checking if the following could be the problem:
- Settings - check that you have set the notifications in your apps settings to have sound turned off to make sure one of them isn't sending you constant annoying messages
- App Problem - there may be an app that is having a software glitch. Don't rush to delete everything, but go through your open apps and turn them off one at a time to see if the prob resolves itself
- Phone Problem - the problem may be with your phone itself. Try restarting it and see if the issue resolves
- Last resort - if the above don't work than I'd suggest resetting your phone to factory conditions
If the problem occurs in safe mode, then what will a factory reset do? Is there a monitoring tool i can use to see what's active the moment it beeps n vibrates?
