Can I get some help with a texting app setting?
  • Start date Start date
A
AC Question
I need help with a texting app settings
I have the HTC One, and on my texting app chomp there is not an option to turn off the vibration while typing a text message. I need to figure out how to fix this.
Re: I need help with a texting app settings
That would be in the keyboard settings, not the texting app settings. Look in Settings/Controls/Language and Input, in the settings (the gear) for the keyboard you're using.
partugyan
