1. AC Question's Avatar
    I have tried smart transfer, transfer from note 2 sd card to note 4 sd card. However I m unable to transfer most of my downloaded shows -just managed to transfer two. - from 32g sd card to 64g sd card. Also my apps are unable to be transferred.
    please help! !!
    04-15-2015 08:12 PM
  2. Rukbat's Avatar
    Plug one of the cards into a card reader, then into your computer. Plug the phone into the computer. Drag the files from the card they're on to the card you want them on. (Don't use a USB hub - connect to the computer directly.) If you use an Anker AR200 reader (about $9), you can just plug both cards (one with a full-size SD adapter) into the reader and plug it into the computer - you'll see both cards and the transfer will be a little faster.
    To transfer apps, back them up to .api files (I use App Backup & Restore), copy the .apk files to the Note 4, tap a file to install it. (If you install App Backup and Restore first, you can just check all the archived files [the ones you copied will be in the Archived tab] and restore them with one button tap. Copy them to the Note 4's internal storage - AB&R won't use the external SD card from KitKat up unless you root the phone and change the card back to the way it was before KitKat.)
    04-15-2015 11:32 PM
  1. How do I get to hands free mode on the S6?
    Last Post: 06-18-2016, 11:30 PM
  2. When is 5.1 coming to Verizon Note 3?
    By TheSkeptic in forum Verizon Samsung Galaxy Note 3
    Last Post: 04-23-2015, 08:52 AM
  3. How do I listen to music on my Note 4 through earphones?
    Last Post: 04-16-2015, 04:51 PM
  4. Replies: 3
    Last Post: 04-16-2015, 11:34 AM
  5. New To Samsung, questions regarding features
    By Tennis4you-com in forum Samsung Galaxy S6
    Last Post: 04-15-2015, 07:35 PM
