A AC Question Apr 16, 2015 #1 how can i disable talkback feature? android cellphone alcatel one touch hero series
Javier P Ambassador Feb 21, 2014 19,480 3 0 Visit site Apr 16, 2015 #2 Re: how can i disable talkback feature? Talkback is usually under settings - accessibility.
W Whitney Curtis New member Aug 1, 2015 1 0 0 Visit site Aug 1, 2015 #3 I does not allow me to scroll or slide to unlock the phone
srkmagnus Retired Moderator May 23, 2010 13,434 210 0 Visit site Aug 1, 2015 #4 Whitney Curtis said: I does not allow me to scroll or slide to unlock the phone Click to expand... Restart the phone and see if that helps. Also, can you double tap (holding he second tap) then swipe while holding? See if that helps.
