1. AC Question's Avatar
    When I go to the Google Play store (either via the web or through the Google Play app on my Note 10.1) it says that the device isn't compatible with Microsoft Office for Android. I can use OneDrive and OneNote but not Word or other Office 365 apps.
    The device says I've installed all of the latest updates. Anybody know if the device will be updated to make it compatible with Office? If not, it adds to my reasons for buying a Windows 8.1 tablet and selling this one.
    04-16-2015 11:50 AM
  2. Rukbat's Avatar
    The question is whether the app will be updated to run on the device, not the other way around. Email the developer and ask. (The email address is at the bottom of the Google Play page for the app. If it's Microsoft, don't expect a meaningful answer.)
    As far as buying a Windows tab, if all you want is office, that's the best way for you. But if you want a large selection of apps, there isn't much in the Windows app store.
    04-16-2015 03:15 PM
  1. My Note 4 is now Slow Charging
    By barskin in forum Samsung Galaxy Note 4
    Last Post: 01-22-2018, 03:10 PM
  2. Can the Android version be upgraded on Asus MeMOPad HD 7 (ME173X)?
    By AC Question in forum ASUS MeMO Pad HD7
    Last Post: 07-27-2015, 02:15 PM
  3. Is Samsung Galaxy Grand Prime getting Android L?
    Last Post: 07-13-2015, 12:51 PM
  4. Should I get the Nexus 9 tablet or wait for a newer model?
    By AliceInNexusLand in forum Ask a Question
    Last Post: 04-22-2015, 08:08 AM
  5. How do I uninstall Tubemate from my Android tablet?
    By AC Question in forum Android Apps
    Last Post: 04-20-2015, 10:19 AM
