Re: wifi and data
No, it should not.
The only thing I know, is that if you have data turned on. And your WiFi stops working for some reason, it could automatically change to data, which can cost you lots of MB.
So, if your WiFi is good, it should not. And, your phone automatically prefers WiFi over data.
