Re: how format curputed sd card
Either boot to recovery and format it there or put it into a card reader, plug that into a computer and format it there.
If neither works, the card is probably bad. If it's a SanDisk card, go to
SanDisk Online RMA Request and fill out the form. Otherwise contact the store or manufacturer and see if you can get a replacement.
