1. AC Question's Avatar
    my sd card is not format
    04-16-2015 01:45 PM
  2. Rukbat's Avatar
    Either boot to recovery and format it there or put it into a card reader, plug that into a computer and format it there.
    If neither works, the card is probably bad. If it's a SanDisk card, go to SanDisk Online RMA Request and fill out the form. Otherwise contact the store or manufacturer and see if you can get a replacement.
    04-16-2015 02:42 PM
  1. How do i factory reset my phone? "all methods have failed".
    Last Post: 04-17-2015, 05:45 AM
  2. How do I remove Picasa from my Note 4?
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 04-16-2015, 05:45 PM
  3. How do I add handwriting to text option in my S6 Edge default keyboard?
    By AC Question in forum Samsung Galaxy S6 edge
    Last Post: 04-16-2015, 01:25 PM
  4. Has anyone else received the OTA 5.1? How's it working?
    By Ntchwaidumela in forum Google Nexus 7 Tablet (2013)
    Last Post: 04-16-2015, 01:13 PM
  5. Replies: 0
    Last Post: 04-16-2015, 12:59 PM
