1. AC Question's Avatar
    I need to do a reset but want to b sure my data was backed up to my google acct. I've looked but don't find anything, are they hidden files or what? How do i find out if data was backed up?
    04-17-2015 04:50 AM
  2. Rukbat's Avatar
    Or read Backing up an Android Phone to back up just about everything - texts, pictures, etc. ("Just about" because I may have forgotten something. If anyone tells me that I have, I'll add a way to back that up too.)
  3. B. Diddy's Avatar
    Welcome to Android Central! Moved this thread to the General Help forum, since the original forum it was posted in doesn't accept replies.
    The data that is backed up to Google is variable, and it can be difficult to know what is actually backed up. See here: https://support.google.com/nexus/answer/2819582?hl=en.
    If you want to make sure everything is backed up, try Helium.
    04-17-2015 02:37 PM
  4. Rukbat's Avatar
    B. Diddy likes this.
    04-17-2015 04:09 PM
  5. B. Diddy's Avatar
    Ach, keep on forgetting about that guide! Ok, it's bookmarked now.
    04-17-2015 05:39 PM
  1. How do I factory reset my ZTE SonatA?
    By AC Question in forum Other ZTE Android Phones
    Last Post: 04-17-2015, 03:30 PM
  2. Factory reset after Lollipop on Verizon didn't help
    By sstephen17 in forum Samsung Galaxy Note 4
    Last Post: 04-17-2015, 11:26 AM
  3. How do i factory reset my phone? "all methods have failed".
    Last Post: 04-17-2015, 05:45 AM
  4. Can you perform a factory reset Galaxy S5 from a computer?
    By Jaime Alvarez1 in forum Samsung Galaxy S5
    Last Post: 04-17-2015, 01:08 AM
  5. Galaxy S5 Active Knox needs to be reset
    By Umass021 in forum Samsung Galaxy S5 Active
    Last Post: 04-16-2015, 10:04 PM
