Re: My problem is my Bluetooth device in car seems to auto dialing my phone
Evidently the phone and car Bluetooth device aren't compatible. (Bluetooth is just a means of getting date from here to there - a pipe - it doesn't specify what data or in what format.) See if the BT device manufacturer has an update for the version of Android you're running.
