1. AC Question's Avatar
    I already have ringtones how do i reduce the length of them so they fit the 30 second rule. is
    04-18-2015 09:28 PM
  2. Rukbat's Avatar
    Try Ringtone Maker. You can change the length, select a portion that's not at the beginning, change the level.
    If you prefer to do it on a large screen, you can do it on your PC with Audacity.
    04-19-2015 12:40 AM
  1. Automatic Dialing of Default Number in Favorites Menu
    By zeewhiz in forum Samsung Galaxy Alpha
    Last Post: 08-13-2015, 08:44 PM
  2. Haven't found a note taking app that can do this yet
    By dropnbassonu in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 04-19-2015, 01:04 AM
  3. Why can't my earphone plug in with my Leo DG280?
    Last Post: 04-19-2015, 12:41 AM
  4. new gs5 owner in need of help
    By vize285 in forum Samsung Galaxy S5
    Last Post: 04-18-2015, 10:10 PM
  5. Is there a way to sort my app drawer by most used apps?
    Last Post: 04-18-2015, 09:54 PM
