1. Debbiemiles's Avatar
    I have a samsung galaxy mini 11 and would like to know how to transfer picture on phone to memory card or evan straight to computer thanks
    04-19-2015 12:24 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! You can use the MyFiles file manager to copy or move the photos to the SD card. The photos should be in the /DCIM/Camera directory.
    You could also connect the phone to your computer via USB, and then use Windows Explorer to drag and drop the photos to the SD card, or to the computer's hard drive. You should be backing up your photos this way on a regular basis anyway, because phones and SD cards can fail--and if that happens, and you didn't back up your photos, they're gone forever.
  3. B. Diddy's Avatar
    04-19-2015 02:49 AM
  1. How do I root Galaxy S4 mini i257 att?
    By Lucas Trimble in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 02-23-2017, 10:58 PM
  2. Replies: 24
    Last Post: 07-05-2016, 12:01 PM
  3. How to update Gear App?
    By Douglas Yarnold in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 04-21-2015, 05:17 PM
  4. Linking Tablet and Phone
    By byrds8 in forum Samsung Galaxy Tab S 10.5
    Last Post: 04-18-2015, 11:01 PM
  5. Replies: 0
    Last Post: 04-18-2015, 09:53 PM
