1. AC Question's Avatar
    hi, I let someone borrow my phone and they thought they were going to steal it, but when I threatened them to give it back, they put a emergency call only on my phone so I can't get in it. It says enter password and it's locked. It's an at&t htc inspire. I've tried holding power button down at same time as volume down and it didn't work. I even put a non at&t sim card in it while doing it. Can someone help??!! Thanks desperately seeking solution
    04-20-2015 12:54 AM
  2. SpookDroid's Avatar
    You can go into the Android Device Manager (log into your Google Play account, it should be there) and reset the lockscreen password as long as the ADM wasn't deactivated in your phone and you're using the same Google account that's logged into the phone.
    https://support.google.com/nexus/answer/3388218?hl=en
    belodion likes this.
    04-20-2015 01:39 AM
  3. belodion's Avatar
    Also, sue this someone for damages.
    04-20-2015 06:40 AM
  1. How do you set up a homepage on an Android smartphone?
    By AC Question in forum Moto G (2013)
    Last Post: 04-23-2015, 05:31 AM
  2. Carrier spyware Android phones?
    By iphone_owner in forum General Help and How To
    Last Post: 04-21-2015, 08:41 AM
  3. Autoplay loaded into my menu
    By Grimgrak in forum Samsung Galaxy Note Pro 12.2
    Last Post: 04-20-2015, 05:31 PM
  4. Will the S5 mini work on Sprint network?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 04-20-2015, 12:46 AM
  5. Replies: 1
    Last Post: 04-20-2015, 12:15 AM
