1. AC Question's Avatar
    Can u plz say how to overcome overheating in panasonic eluga I model.. talking for few mins makes the phone so hot ... totally disappointed.. is it because of android kitkat version or some other problems???? plz tell me how to rectify the problem...
    04-21-2015 02:35 AM
  2. B. Diddy's Avatar
    Hi, did you also post this other question? http://forums.androidcentral.com/gen...installed.html. Please refer to that thread for responses, and consider registering on this forum so that you can respond within a thread (rather than posting a new question that is identical or very similar to another).
    04-21-2015 01:18 PM
  3. Vishwagar's Avatar
    Dear friends,
    Panasonic Eluga Z im using Its every time automatic doing contact update. some times not yet shows my contact also, once i restart my mobile it will fixed temporarily but its more irrigating with this problem and sometime heating also. i so fed up with this problem.........please any body knows about this problem pls fix it.........thanking you
    04-05-2016 03:14 AM
  4. Laura Knotek's Avatar
    I'm not sure I understand your question. Are you saying that your are trying to sync but the sync never completes?
    04-05-2016 03:16 AM
  1. Why aren't I getting network on my Lava mobile?
    Last Post: 04-21-2015, 01:56 PM
  2. Replies: 1
    Last Post: 04-21-2015, 01:55 PM
  3. How do you create a genre playlist in Google Play?
    By AC Question in forum Google Play Store
    Last Post: 04-21-2015, 01:52 PM
  4. Where do I need to go to view pdf files I downloaded a second time?
    By AC Question in forum Samsung Galaxy Note 2
    Last Post: 04-21-2015, 01:49 PM
  5. External SD card missing in DocumentProvider
    By hobbes444 in forum Legacy Android & Other OS's
    Last Post: 04-21-2015, 02:08 AM
