How can I get my phone to turn on?
A
AC Question
It will not tuarn on
The green light is on. I press the button for 1.5 seconds. Nothing happens. I have tried this with and without the chargewr attached.
belodion
Co-Ambassador Team Lead
Moderator
Jun 10, 2014
39,380
248
63
Re: It will not tuarn on
If you're sure that the charger, USB lead, and USB port are undamaged, you might try a new battery.
Dawncompton
