1. Partha Dhar's Avatar
    Hello Guys
    Is there anyway to restore WhatsApp dbcrypt8 without the key ?
    Here is the situation..
    I had whatasapp installed on bluestacks on my pc. I uninstalled and removed Data and SDCard.sparsefs but the file > msgstoredb.crypt8 on 2015-01-29, didnt knew about the key file then.
    and switched to my new device but forgot to restore the chats.
    I have two device for now (one is rooted) and my chats got messed up so i did merged them but can not merge the bluestacks' one, maybe because its too old.
    So any other ways to merge them ???
    Thanks in advance
    04-21-2015 02:44 PM
  2. Rukbat's Avatar
    No. There are very few file formats you can just "merge" without the app that created them. (IOW, if Whatsapp had an "import" facility, to import an old chat file and append it to the bottom of the current one.) Files usually have metadata at the beginning, and appending that to the end of another file gives you metadata where the program is expecting data, so it sees it as garbage and either blows up or truncates the file at that point. (You can append 2 text files - there's nothing in them but text. You can't append 2 Windows Word .doc files because the second one has a header where Word is expecting to see more text.)
    Add encryption and it just complicates matters.
    04-21-2015 03:10 PM
  1. Replies: 10
    Last Post: 08-18-2015, 09:31 AM
  2. Replies: 1
    Last Post: 04-27-2015, 12:10 PM
  3. Replies: 1
    Last Post: 04-21-2015, 05:36 PM
  4. Replies: 1
    Last Post: 04-21-2015, 03:41 PM
  5. Back of phone dropped in water, however phone still turns on and off by itself
    By jcrolltidemoore in forum Samsung Galaxy Note 4
    Last Post: 04-21-2015, 01:34 PM
