1. AC Question's Avatar
    the flashlight and video camera light turn off when upside down
    04-22-2015 02:57 AM
  2. Paul627g's Avatar
    Depending on which device you have this could be happening due to GESTURES under Settings. I know on my LG G3 flipping the phone can either ignore/silence an incoming phone call or snooze or stop alarm.
    Something to check into.
  3. Paul627g's Avatar
    04-22-2015 09:53 AM
  4. Minervagomez's Avatar
    I have a galaxy s7 and was having the same issues, I replaced the phone twice and was still encountering the same issues. My carrier finally told me to contact samsung directly. I called, explained my issue and it was resolved in a matter of a minuet!
    Here is what was wrong. When I got my phone I turned on the "EASY MUTE" option with is located in the settings followed by "ADVANCED FEATURES". That is when you receive a call or the alarm goes off and want the phone to silence quickly, you simply flip the phone face down to mute it immediately. Well little did I know that this option effects the flashlight. Every time I turned on my flashlight, locked the screen and flipped it screen sided down it turned off.
    I hope this helps and save you some phone time with Samsung reps. I was on the phone for a little more then a half hour before I was transfered to the right tech who helped me with just 4 simple steps!
    11-13-2016 01:59 AM
  5. James Amankwah's Avatar
    01-15-2017 06:33 PM
  6. James Amankwah's Avatar
    Thanks it work for my s6 edge
    01-15-2017 06:36 PM
  7. James Amankwah's Avatar
    It worked for me
    01-15-2017 06:37 PM
  1. Replies: 1
    Last Post: 12-01-2015, 08:04 AM
  2. How to switch on MMS in Samsung Galaxy V smart phone?
    Last Post: 04-23-2015, 01:34 AM
  3. Why can't my Nexus 6 send contact list to 2015 Audi SQ5?
    Last Post: 04-23-2015, 01:31 AM
  4. Something Is Wrong With My Google Play Services
    By conno23 in forum General Help and How To
    Last Post: 04-22-2015, 01:52 PM
  5. Which Android phone use Power VR gpu?
    By gfederline9 in forum Samsung Android Phones
    Last Post: 04-22-2015, 01:23 AM
