1. AC Question's Avatar
    my home password for Wi Fi was saved, and worked, but now I got error that password is incorrect. Wi Fi is working in my Samsung Cell.
    It gives error even I try to establish connection to non secured Wi Fi
    04-26-2015 03:36 PM
  2. Rukbat's Avatar
    Assuming you didn't change any of the advanced settings, it sounds as if the wifi radio or the modem (the radio software) went bad. If it's under warranty it's covered. Otherwise you'll have to decide whether it pays to fix it. (You didn't tell us which phone it is. It pays to fix a $700 phone, it doesn't pay to fix a $35 phone.)
    04-26-2015 07:25 PM
  1. Unable to access Samsung Account/Theme Store
    By intelo2 in forum Samsung Galaxy S6
    Last Post: 10-11-2016, 04:17 PM
  2. Why can't connect my Galaxy S6 Edge to my new Samsung tv?
    By AC Question in forum Samsung Galaxy S6 edge
    Last Post: 10-08-2015, 04:37 PM
  3. Replies: 2
    Last Post: 04-27-2015, 02:44 PM
  4. Replies: 1
    Last Post: 04-26-2015, 07:30 PM
  5. Replies: 0
    Last Post: 04-26-2015, 03:02 PM
